I just got my FP earbuds which I bought in a hurry after realising that it’s a mandatory purchase if you don’t have wireless ones yet. Unfortunately, I now noticed that even the smallest size of the silicone tips at 12mm diameter seem to be too big for my ears. My previous cable headphones’ smallest size, which fit quite nicely, are 10mm. I can’t use them though, because a) they don’t fit on the earbuds and b) they are of a different colour, so it would be really ugly.
I noticed quite a few people writing about the same problem in the reviews, so hopefully they will add an extra size in the future. In the meantime, does anybody know of a smaller 3rd party silicone tip that fits the FP earbuds?
Thanks!
Linus
