Hi, does anyone else use Skype on a FP4 with LineageOS 20.0? Here the voice of the other person sounds extremely high. That is very funny but not as it should be. Any ideas what to do for a normal sound?
I have the same issue with Skype on e/OS which is based on Lineage AFAIK. It sounds like Mickey mouse. On my Samsung tablet with e/OS it works fine.
Not found a solution so far. If someone has any ideas please help us.
same here, LineageOS. the fun part is the reason I upgraded from samsung S5 was skype.
related thread
I have the same problem with Calyx. My research led to the explanation for the same problem in Windows that Skype does not recognize the sample rate correctly. But I don’t know how to check or correct that in Android.
