SIM 2 has no LTE?
hi,
I use two SIMs with identical prepaid data flatrates. When I switch data connection from SIM 1 to 2 there is no 4G sign and the data speed is awfully slow.
what’s up with that?
Best regards
Klaus-Peter Zeyen
Only one SIM card can be set up to use 4g.
Please check out the following topic and continue there if you have the same issue:
Lösung gefunden. unter Mobilfunk Netzwerk SIM 1 auf 2G setzen, dann geht auch der Wechsel von SIM 2 auf 4G
