Is it possible to show the room temperature on my FP6 ?
Es gibt diverse Thermometer Apps, die angeblich den Akku und CPU Sensor mit KI kombinieren und die Raumtemperatur ermitteln. Ist aber um 3 Grad C ungenau…
There are many Apps in Play Store call Thermometer, the can Show room Temperature by using temp Sensor of CPU and battery Sensor. But the accuracy isnt bettet than 3 Grad C.
Could ypu kindly translate into EN? Thanks
Thanks for this information. 3 degrees is to much for my situation. I will mark this wish as impossible for the PF6.
I doubt that any accurate reading would be possible in the way you imagine: The best you could get is the temperature somewhere on the phone where the sensor is placed. But a running phone will naturally produce some heat of its own and this will always influence the results. Depending on how you used the phone last, this will not even be constant.
You would need a detached sensor to avoid that - not very practical.
