I’ve reported it to official support. Will report back if they come up with anything.
Hi all
just my few cents here:
As far as I´ve understood the issue described here it´s about links disappearing on the default android launcher after a reboot whereas there seems to be less or no such issues with other launchers (for example Nova, etc)
The first thing I´d search for would include such phrases like ‘(default) android launcher links disappearing’
By doing that I can see a lot of hits in forums starting about the end of 2021 in combination with several different mobile manufacturers. All about Android 11 and Android 12.
Therefore I´d rather suggest contacting google about this issue since the default launcher is maintained by them and the issue seems to show up across a variety of mobile models/manufacturers.
For example take this post in a different forum (about a moto 8 and a pixel mobile) and scroll down to the last comment
Alterntively (or to prove this assumption) you could test and install a different launcher and see if the situation is still the same.
But if other launchers don´t show this issue then the responsibility for fixing it is rather up to Google instead of Fairphone.
Best
DonFnord
Even if this might be the case, it should be of no concern to the end user.
Fairphone support their OS. Fairphone can surely determine whether they can do something themselves or whether they need to take things up with Google upstream.
Thanks for the comprehensive response Don.
If Google are aware of it then I don’t think I need to report to them, thankfully (because God knows how).
Regarding an alternative launcher, Nova is tempting based on the Google Play rating and reviews, but one of the big advantages of the out-the-box settings is that I can easily talk my old mum through any problem she has because I managed to persuade her to buy a FP3 too (partly for that reason!).
I think I’ll try to hang on for one more shortcut loss at least before I get too frustrated and try a different launcher.
You´re welcome @el_foz
I didn´t know about your use case for your mom and I agree that Nova with all its settings could be a step to much for less tech-affine people.
With this in mind (and even if it´s not a true launcher), probably it´s worth for you taking a look at ‘simple launcher’.
There´s ot a bunch of setting to dig through and it should be easy to use:
Play store: https://play.google.com/store/apps/details?id=com.simplemobiletools.applauncher
F-Droid: Simple App Launcher | F-Droid - Free and Open Source Android App Repository
Best
DonFnord
I’m not sure that is very representative, Nova launcher doesn’t require any demanding set up, there are options but they don’t have to be used.
Fairphone support replied suggesting updating to the latest OS (which is what caused the issue this third time), and then resetting to factory settings if that didn’t work.
This is why I don’t report things to Fairphone support.
I might try an alternate launcher if it happens more frequently, but I tried Nova briefly and felt a bit overwhelmed so uninstalled it.
That seems odd to me as I didn’t really have to do anything unless I wanted to customise it ??
Having never been able to reproduce the problem, yesterday / this morning I have at last done so. All the shortcuts I created back on 28th June (see above) and since, have gone. These were mostly web-related, either simple URLs or PWAs created from Firefox, but also one Contact.
What might be useful in this, is that I know what I did differently last night. As I’ve already said in this thread, I turn my phone off most nights and have never encountered the problem before, but last night I needed to check something in fastboot mode. So I turned off the phone, then turned it on in fastboot mode, and having done what I wanted to do, used “START” to boot into FPOS. I hadn’t done this since creating the shortcuts back in June.
Unfortunately I’m not able to reproduce this just by returning to fastboot and then STARTing, but this info might point to something related to boot conditions which could explain the apparently random occurrences of the bug.
I have an SD card but frankly I don’t think it’s related. Looking like a FPOS Android 11 thing as things stand. And to be clear: it’s not just web shortcuts, any sort seems potentially affected, all mine disappeared at the same time.
I have informed Fairphone.
4th occurrence this morning. Phone was running slowly and Ecosia kept crashing so I rebooted. All Internet shortcuts gone and all WhatsApp chat shortcuts gone, from the home screen.
Don’t know about Drive shortcuts because I hadn’t bothered recreating them after the 3rd loss. Box shortcuts survived this time.
I’m getting closer to giving Nova another try since Fairphone Support had nothing better to suggest than a factory reset.
It’s a long shot, but there has been a plethora of people complaining that launchers keep asking to be set as default, the problem being attributed to the ‘Well being’ app. Maybe something similar is happening here
Have you tried a) A Safe mode start and b) disabling the Well being app and as many others of the default you can?
https://support.fairphone.com/hc/en-us/articles/360048843571
The shortcuts disappear after a reboot so I’m not sure I see how using Safe mode would help?
First there was this
I thought starting in safe mode would first check out that no custom apps were dragging the phone’s ability to running slow and crashing, and at the same time internet shortcuts can be made from chrome, the default browser ~ then it can be assessed if the shortcuts and other issues survive an intentional or otherwise reboot.
How do I restart in Safe mode? Although if I do, and the shortcuts remain, it doesn’t tell me much because they only get deleted after some reboots (4 since opening this thread), not every reboot.
I’ve disabled Digital Wellbeing now, since I don’t use it, so we’ll see how things go for a while.
There’s a link in the post where I mentioned it Let’s hope disabling Digital Wellbeing does the job.
Starting in safe mode would be a laborious option but you mentioned other problems too.
- The phone may not run slowly
- Using Ecosia as a search engine in chrome should require any custom apps.
The idea is that running in safe mode without any custom apps would help eliminate them as problems, whereas the disabling of Wellbeing can be done in either case. Hopefully the later is all that is required.
After taking some photos this morning, all of my chrome shortcuts, which i had saved in different folders to my homescreen have disappeared. The folder icons are gone leaving an empty space where they used to be.
Rebooting several times has not helped.
Luckily i use Bookmark Folder App, which has kept a back-up of the various shortcut links, but what an inconvience.
Running latest Software and Security updates.
Has anybody else experieced this?
Also is there anyway to get them to reappear?
Update: 8 reboots (including a security update on the 6th) since disabling wellbeing and still no loss of shortcuts. Pretty conclusive I’d say. I’ll reopen the support ticket and let Fairphone know. Maybe they will have a better suggestion than restore to factory settings now. Maybe not!
Well thanks for the update. That well being app seems to conflict with a number of opp’s. (launcher request)Luckily it was one of the first things I disabled and then uninstalled, so never had an issue
Unfortunately for me, disabled the Digital Wellbeing app, rebooted, and at the very first attempt all shortcuts were deleted again.
So while the solution may work for some, it is not a reliable workaround…
Apparently there are other apps that can be disabled . . .
