Several issues - maybe core module broken? bad signal, bend to work, reboot loop, unexpected reboots
I have several issues with my Fairphone 2:
A) bad signal (1 – 2 times a day)
B) Display some times only working if I bend the phone case (1 time a day, but recently more often)
C) cannot turn off phone, it always reboots (always)
D) Unexpected Reboots (~ 2 times a day)
Here are more details on each issue:
A) I am experiencing this since minimum 1 year (probably even longer). It only happens from time to time so it’s hard to nail it down. If it happens my phone indicates that I have signal but e.g. loading a webpage won’t work because I have no Mobil connection. Or I try to make a call, the phone dials but then after some seconds I get the message “no signal”. It also happens quite often that some one tries to call me but I’m not available. When the problem occurs I can usually feel that the phone heats up quickly in the top area and the battery is loosing power very quickly. There are 2 ways to fix: either just wait some minutes until the phone “recognizes” and starts to register to the network again. Or I enter flight mode for min 10 seconds then disable flight mode again. I already changed the Carrier and also reset my phone completely. I also tried different versions of FP OS as well as linage OS. None helped so far. I also checked connection of antenna cable, cleaned contact pins, disassembled and put together all modules. No success.
B) I see this issue since approximatly since one month now. The last 2 days it increased, so that it is hardly possible to use my phone. The problem is that the phone is acutally working fine but when I try to unlock it the display just stays dark when I press the standby button. If I bend the phone (not sure where or how excatly I have to bend) the display comes up. Some times it keeps on working fine – some times I have to bend it continuesly in order to make the display show something. If the display is once on and I relief the bend, the display either just freezes or shows stripes, greys out the screen. I first thought that the display module is broken again but I switched to a completly new display module and I can see exact same behavior. I have the feeling that it is somehow related to temperature. I‘m not sure but it feels like its working better when the phone is colder.
C) This happens since I switched to the new camera module. I‘m running Lineage OS. I just found this post while typing these lines and it seems that it really fixes my issue :slight_smile: Now I can finally encrypt my phone!
D) The phone just reboots. I think it happens like > 2 times a day but very often I do not even realize it because when I put it out of my pocket it is just as before. But I usualy realize it min. once a day.
Conclusion: I suspect that the core module is broken as the cause for A) and B) maybe also for D). Hence I would like to get a new core module. As far as I understood I have to write to the support team for that. But it also seems that the core module then costs arround 300€ which is too much for me. For 300€ I can even get a refurbished FP2 or any other phone.
Does anyone of you have different suggestions on what I can do? Or what the reason for one of the issues might be? Or maybe suggestions on how to fix one of the issues?
If you happen to have fairphoneangels in your vicinity, they might be able to help you check which module is at fault by swapping them.
Activating the flashlight is just a workaround.
The issue was supposedly fixed in LineageOS back in March, which build are you running?
You might be interested in the rebootsguide .
Thank you for your answer!
I will get in touch with a fairphoneangle regarding bad signal A) and bending the phone B).
C) Indeed I’m running LinageOS 15.1-20190227. I will also update to the latest build. However, the problem is fixed already by applying the workaround once (turning off phone while flash is on). If I now turn it off, it stays off. But it’s always a good advise to update to the latest version.
I checked out the #rebootsguide but I find it quite hard to narrow the reboots down to a specific situation. So far I wasn’t able to determine a specific scenario, location or app usage when the reboot occurs.
Heyas, I have sent in my phone with quite similar symptoms. I will receive it soonish with a new bottom modul + new battery, both on warranty. I can let you know if things improved, also in case I get an answer from support how bottom module was related to the symptoms.
@sniggles thank you. Which of the issues described do you mean? I would be very interested to hear if your issues have been fixed by replacing bottom module and battery. Can you already give feedback? I already replaced display module for a test but that did not help anything.
I made the same experience; issues were gone for a few days but then reappeared quickly and frequently. will contact support again as soon as I catch the issue on video.
Mainly the lacky input is back. So I can’t type anymore and the phone freezes. Reboots, which I had pre-repair, didn’t reappear, neither the unexpected reboots. So reading your message again B,C,D didn’t come back yet, A I didn’t witness at all.
Seems like for your issues the fix did work so far :wink: For mine (which seems to be a different one) it didn’t fix it; which I was expecting to be honest.
Anyways, hope I could help. Good luck debugging :+1:
