Second SIM-CArd in a Fairphone 3 +
I want to use a second SIM-Card in my Fairphone 3+ . I wonder what content '(WhatsApp, SMS, …) will still be seen when I disable the second SIM-Card or when I remove it from the Smartphone comletely.
As my Smartfhone is used by my kids to play games or whatch movies I want to be sure that they will not change or delete messeges, contacts or so by playing whith my Smarphone.
Whatsapp, or apps in general are not bound to the sim-card. If you remove the sim-card, everything, including whatsapp, works just the same as before.
All whatsapp does is sending you a code via sms to verify it truly is your phone number.
