That does not work for everyone, for whatever reason.
For me it does!! Very handy!!
@yvmuell Do you mean that the normal way of screenshotting from the app switcher (via a button at the bottom of that screen) doesn’t work? If so, that doesn’t work for me either. It vanished when I lost all the other methods. But tapping on the app icon to access it from a submenu still works for me. Maybe it will still work for some other people too. At the very least, its one more method to check on before falling back to a new install.
as mentioned already above the new way works for some and not for all,
I already did contact support about this issue, they can’t help me.
And this didnt help?
Nothing helped until now Yvonne
. And it’s pretty annoying I can say.
I wouldn’t know how to change the display duration as the post says.
And support doesn’t know either
A little news and option, if you are inclined
https://www.xda-developers.com/slicedtoasts-android-toast-notifications/
Xposed modules would require Magisk to install, so I wouldn’t recommend it in this specific case.
@Mariannevl So the toast persists really for longer time? Does this happen with all toasts or just the ones from the Gallery app?
Hi @Mariannevl,
@Martin_1964 just proposed the following in a German speaking topic regarding the same issue:
This translates to Settings -> Accessibility -> Timing controls -> Time to take action (Accessibility timeout).
Default should set the mentioned two or three seconds, all other entries of course whatever they state.
Was just about to post the same ![]()
Should be Instellingen → Toegankelijkheid → Bedieningselementen voor timing → Tijd voor actie
Thanks guys but that is not what I mean.
Let me explain: I see notifications on the bottom of the screen when I have done actions. For example: contact added, photo saved or photo shared, or uploading photo, or even agenda item saved.
Don’t you recognize this? No-one?
Yes, the description and shown animation of the option doesn’t really match the affected component. This is what the other topic was about:
Exactly! That is what I mean!
Yeah, it seems the toasts are influenced by Time to take action too, even though one can’t interact with them. You should check this setting and I will file an Android bug report that it may make sense to let toasts disappear after the normal timeout if you click them. This will likely take a year or two, if they even accept it. ![]()
This will likely take a year or two, if they even accept it. … ![]()
Thanks so much!
Ik will give it a try though. Many thanks!
(Deleted and opened a separate thread)
About screenshot:
Works fine for me. Basically this replaces the button we used to have below the vignette in A11.
