Screen auto brightness out of function
The screen won’t adjust to light conditions. Yes, I’v set it to ‘adjust for light conditions’.
  1. What exactly does it say in Settings - About phone - Build number?
  2. Anything in here that helps? …
Ok, it seems then there’s nothing to do about it…
Install an app which can display the brightness sensor value. It should display different values if you change the light conditions significantly.
The screen auto brightness has never worked on my FP2. I’ve just set it to maximum to be able to see in daylight. When I turn on the “Adapt brightness to conditions”-option, the brightness slide control is still there - which is strange.
I posted this question some year ago but it never got solved, so I’m trying again…
What did you already do to solve it?
Did you contactsupport ?
Or did you try this to see whether the brightness sensor works …
It’s not strange, it’s how adaptive brightness works currently …
