Sailfish OS 4.5.0.19 release6 for Fairphone 2
Sailfish OS 4.5.0.19 release6 is now ready. Installation and update instructions can be found at Adaptations/libhybris/Install SailfishOS for fp2 - Mer Wiki.
Note that updating to this release is required before updating to the next release. If you are updating from a release older than 4.4.0.72 read the instructions carefully to see which intermediate updates are needed. Latest image (and also changelog with instructions) can be found here. Highlights of the new release:
  • Updated to Sailfish OS 4.5.0.19
  • Based on Android 6 (18.04 release)
Sorry again for the delay with the release.
IMPORTANT When updating from releases older than Sailfish OS 4.1.0.24 be very careful to update first to 4.1.0.24 following the instructions at https://forum.fairphone.com/t/sailfish-os-4-1-0-24-release2-for-fairphone-2/75384.
Known issues:
  • Camera configuration files are no longer used. If you encounter any issues with camera please report them.
Upgraded about an hour ago. So far no camera issues - front, back and video recording all is fine.
Btw. regarding “devel-su version --dup”:
The instructions state to run “devel-su ssu release …” instead of the usual “ssu release …” when upgrading from 3 to 4 (I had this situation). IIRC this involved copying some config file manually. Do you think it is worth checking for future releases?
Thanks for the good work as always! :+1:
I added the missing devel-su to the instructions.
