[ROM][UNOFFICIAL] LineageOS 16.0 for FP3
What is the current state of LineageOS for FP3? As long as it’s missing there also wont be any version for https://lineage.microg.org, which is preventing people who don’t want GAPPS to use Exposure Notifications for Corona warn apps.
That is not entirely true, as there is a version with microG linked in the top post…
I tried this ROM, but unfortunately it didn’t work for me. I updated microG and the German Corona Warn App started working. But at some point, it refused to work. It just said there was a problem in communication between the app and the Google API.
I just couldn’t find out what the problem was, but I tried switching to LOS 17.1 GSI, which worked.
There were just to many un-knowns for me to find out the cause for this problem: an unofficial LOS, an updated microG, the Corona-Warn-App. And with the rising infection numbers too few time to search for the cause.
Yeah, I had the same issue. You need to update gsmCore again to version 0.2.13 from Oct 19 to get the CoronaWarn app running. Unfortunately, I had to trigger that update manually in my Droid store.
Oh well, now I have to find out how to update it on the LOS 17.1 GSI :wink:
Does the 0.2.13 version work with Corona Warn App 1.5? After the update of the app, I had the same issue as before on LOS 16 and downgraded it again.
Edit>: OK, got it updated, but I don’t dare to update the Corona Warn App, as I am afraid of loosing my stored contacts (again).
Ok. But for the record:
CoronaWarn version 1.5.0.47 runs with microG gsmCore version 0.2.13.203915.203915026. The prior Version of CoronaWarn (I don’t remember the exact version string, guess it was 1.4.0.something) worked with version 0.2.12.203315.203315024 of aforementioned gsmCore. I use the microG repository for the F-Droid stores.
I updated, everything is fine…
Hey folks! I’m curious, if there are any news regarding the official LineageOS build?
Very kind of you to take an interest. The code and commit history cleanup I mentioned above is done. We are setting up automatic builds (Hudson) and a Wiki entry at the moment.
Most likely this is the wrong place to ask, but maybe I’m lucky:
Is there a way to keep (backup and restore) my collected data of the Exposure Notification of microG or the Corona Warn App?
Background: because I had problems with CWA and microG on this ROM I switched to 17.1 GSI. Of course I would very much prefer to use an official LOS over using a GSI (which is very well maintained, but likely not as future-proof as an official ROM). So if 16.1 will become official, I would of course prefer to switch to 16.1 without loosing stored identifier keys.
Sounds good! Can you also tell if you are already working on the integration of the new camera and speaker (modules) for the Fairphone 3+? Or maybe you @Alex.A, since you mentioned that you plan it for the end of October.
/e/OS is coming to the new camera and speaker modules end of october. Not LOS.
Quoting above:
@dk1978 Congratulation on getting official LOS 16.1 support for FP3 :clap:
I thought you were talking about the release of a first official build and rushed to the official lineage download page to get it. Bummer. :wink:
actually I can already see that the fp3+ has been added on their shop page, so I guess the ROM is ready, but in the device list there’s only the fp3 and shows to be compatible only with fp3, I was expecting fp3/fp3+ at this point.
Patience still required I guess
You guys are plain awesome. :grinning:
It will take a few more days, and then everything should be ready of official Lineage OS 16.0 on FP3. I will also open a new forum topic then and maybe migrate some posts if possible.
You are the one that is awesome, @dk1978. And @Max_S of course. :smile:
Thanks for all the work and efforts you put into this.
Thank you very much for your work. Initially, I was waiting for LOS coming to FP3 before buying it. Since my FP1 resisted the charger too much lately, I had to buy “early”. Now I am waiting eagerly for the official release. Really looking forward to it.
I am waiting for the release too. :slight_smile:
Hurray!
A big THANK YOU for the developers!
