Restart not restarting
Twice in recent days I have tried to restart my FP4 from the homescreen by tapping Restart after long-pressing the fingerprint/power button. Both times, the phone has shut down completely but not restarted. First time it happend it freaked me out a bit because I have never seen it do this before, and my first thought was the phone was done! Has anyone else seen this happening?
Yes, i know this also. I just start it then manually… For me it’s not a big issue. But ok, would be nice if it worked as expected :wink:
Hi, as I wrote several times here (e.g. Software Update: FP4.QREL.15.17.2.20260415141502 📲 - #25 by KleinerAdmin), I see this behaviour too with my FP4 together with a loose of USB connectivity since a longer time. Short time after restart, everything works fine (restart, USB). Some hours later, the phone does no longer connect to my PC via USB and a restart leads to full shut down and I have to long-press the start button.
In my case I suppose the reason is that I installed the buggy FW 15.15.2 times ago which bricked serveral FP4s. First I thought my phone was bricked too, but it restartet after long pressing the start button.
Thanks for the replies. This is exactly the reason why I restarted the phone! My USB headphones suddenly stopped being recognised by the phone. I didn’t install the dodgy update, but I’ve every other update installed. I haven’t used my headphones in a couple of months, but it didn’t do this before then, so I’m guessing it’s an update issue. I’ve no problems with the USB port because it charges without problem. I also have used it with my PC and when the headphones stop being recognised, it also stops working with the PC too. At least I’m not going crazy thanks for confirming it’s wider than just my FP4.
