I also noticed that I can reproduce the issue pretty consistently if this forum is the first page I load after killing Firefox and clearing the cache, whereas it usually works if I load some other page first and only then open the forum.
Interesting. I don’t have the feeling that I saw the same correlation so far. When it happened I repeatedly killed Firefox and opened that page first until it worked. But I had just as much trouble when I had been browsing other pages in other tabs before.
Probably this is not related, but can anybody open https://www.vmt-thueringen.de/ and try to pick a date and time for routing information? Doesn’t work for me on Firefox mobile, the calendar is strangely ordered, so I can’t confirm the date. Chrome seems to be working
Just to follow up: I have seen this happen plenty of times on Version 117 by now. So it does not seem to be fixed and is just luck.
No difficulty finding a train from Plaue to Erfurt Hbf next Wednesday morning ![]()
Firefox 116.3 on FP4.SP2K.B.089
@OldRoutard
you really should update your Firefox, 117.1.0 fixes a critical zero-day: Security Vulnerability fixed in Firefox 117.0.1, Firefox ESR 115.2.1, Firefox ESR 102.15.1, Thunderbird 102.15.1, and Thunderbird 115.2.2 — Mozilla
Thanks for testing. Maybe it is caused by uBlock origin ![]()
I already tried disabling all that. It’s also not FP4 specific. The FP5 has it too and I could also reproduce it on my Pixel 3 for quite some time.
I have missed this topic so far, but I have the same problem every now and then (it usually helps to force close FF and then try again). Will head over to bugzilla later.
I saw this thread sometime in the past, but didn’t care too much, because for on my computer was doing five. Now I changed from Lighting browser to Firefox when I moved from FP2 to FP5 and I have the issue both here and in a different forum based on the same software. I’m using uBlock origin, but otherwise the browser is more or less as it came. Will try to disable uBlock next time this happens…
That is interesting! I just came over here to say that on my FP4 it worked every time since I updated to A13. ![]()
I’m using the forum in a Firefox PWA which did not load at least half of the time before. I had to kill it repeatedly until it worked.
disabling ublock and decentraleyes doesnt change anything for me.
Interestingly I didnt have problems for app. 1,5 weeks until 5 days ago it started to happen again from time to time.
Confirmed: Right after posting my previous message here I had the issue again, disabled uBlock and that didn’t change anything. Increasingly enough another website in a different tab didn’t want to load properly then anymore, either, although that page alone doesn’t have any issues normally.
In my experience the only thing that fully prevents the problem is to
- Enable the following setting: Delete browsing data on quit
- Check the following boxes: Open tabs, Browsing history, Cache
- Always use Quit, which will appear at the bottom of the app menu, after visiting a Discourse site.
These measures are not too detrimental I find, as long as you don’t rely on browsing history.
With me, the bug recently got much worse. The above procedure no longer works and I can’t load the Forum at all. I suppose I could if I wanted to empty all data, but that’s getting ridiculous. Clearing the app cache doies not help.
For the moment I’ve fallen back on another browser (DDG) just for Discourse.
Anyone else see this?
I switched completely to Vivaldi due to this.
I’ve always been using Vivaldi and have never faced the problem.
I don’t need to clear all data. All that’s sufficient is switch to a non-discourse page, “throw away Firefox” by swiping it out in the square button menu, and then relaunch it again. Sometimes I need to repeat this up to 10 times, but I’ll always get there without clearing data.
Yep, same here. After the A13 update I had no issues at all for some time. But since a few weeks it’s back. Sometimes better, sometimes worse. But with enough tries it works eventually.
yes that helped, thanks! I could then load the forum and things seem back to “normal”.
