Hello! I purchased a Fariphone 6 from my provider and it of course came with Android 15 pre-installed. My goal is to put /e/os on it and I am just wondering if there is an official source that the Fairphone team uses to install it? Which link is the safest, in other words, and which guide is the one that the Fairphone assembly team follows?
Thanks!
I’d say the natural choice would be to look at the official /e/ homepage, use the official installation instructions that point to the official download location.
Start here: Get /e/ OS - e Foundation - deGoogled unGoogled smartphone operating systems and online services - your data is your data
There are other community written guides like A clear guide to install /e/OS on your Fairphone or probably also some in the /e/ forum at https://community.e.foundation
In case something doesn’t work during installation, maybe someone else has already reported/solved the problem. In that case you could look at
https://forum.fairphone.com/search?q=fp6%20%23eos-murena%20order%3Alatest
