Reboots after A15 upgrade
A lot of random reboots is caused by the configuration of 4g/5g on particular transmitters. So yes, it is most probably related.
urgh okay.
Not sure if this helps anyone, but for context: this happened in Japan with UQ Mobile carrier
I would like to advise you set your SIM card to 4G/3G/2G only. No 5G.
To me, these reboots also happened in Japan! Two were in Osaka near the castle. One was somewhere in shinkansen, and the last one I don’t remember.
After disabling 5G, I got no more reboots (but we were travelling all the time so I can’t say for sure if it helped).
On the other hand, I’ve now spent 2 weeks in Indonesia (often on 5G) and no problems.
I’ve tried this after seeing your comment, and have not experienced a single reboot since!
Came here and created an account just to write: finally, worked for me!
My Fairphone 4 was starting to have battery issues on Android 13.
I’d heard about the problems with the update to Android 15 in 2025. I only got it at the beginning of the month, thinking there must have been fixes since then, but I really regret doing it.
Now my phone is unusable. It’s that simple. It keeps rebooting!
On the first day of the update, I left it overnight with the battery dead. The next day, when I restarted it, it worked… I took the opportunity to clear the cache on all my apps and close everything. It worked fine after that, but this morning, I rebooted my phone… It’s been rebooting for two hours now. It stays on for about one to two minutes, whether I’m doing anything or not, then it shuts down. Sometimes it stays off longer than others…
I tried the NXT trick anyway, but it didn’t make a difference, and my screen didn’t have the advanced display settings, so that’s not the issue.
I also disabled the 5G network, but that didn’t change anything.
My Android version is fp4.qrel.15.16.1
Hello and welcome to the community forum
Could you tell us where you are based and with which provider? One/double SIM?
In France, my provider is Orange and I bought the phone directly on your website. Only one sim card.
Thanks
hi
thank you.
I do not have any specific advise apart from perhaps trying a safe mode and a different launcher.
perhaps someone would have some other/better ideas.
just a note - it is not my website, as I am not the company rep:)
Try in dic:safemode
If possible try without SIM. Try with Wifi Calling didabled. Try with VoLTE disabled.
@peci1 @DeinAlptraum
Hello it is funny (?):
I happened to be in Japan for some time and the reboots re-happened!
What I had changed from my usual sim card in France (Source :droplet: provider, which is a “fair” Bouygues brand) is that I used an UBIGI esim which seemingly connects to 5G networks.
In France my subscription is only up to 4G…
Now back in France again, no more random reboots :smiley:
Note: I saw a commercial for Softbank where they sell Starlink subscription, maybe this fryed my FP4? :rofl:
5G has nothing to do with it, I’ve been using it extensively (Orange FR) for years.
What could have happened is that the Japanese network is using some feature which causes those reboots. I remember FP5 (or FP6?) users did experience this after upgrading to A15: Everything worked in Europe, but the phone was constantly rebooting while roaming in the States.
In other words, don’t travel to Japan with your FP4. :man_shrugging:
That’s definitely a possibility… Did you catch a whiff of Musk? :laughing:
What frequency bands are being used in Japan? Maybe FPOS does not work well with certain bands that are not being used in Europe.
I will if get the opportunity :grin:!
Best regards
I don’t know the frequencies, however the provider of esim Ubigi states that uses the following networks:
KDDI 4G, 5G and/or NTT Docomo 3G, 4G, 5G.
Adding a data point: airplane-mode elimination test points to the radio/modem in marginal or foreign-network coverage
Following the recent discussion about specific bands/networks (and the FP4/FP5 reports of reboots while roaming outside Europe) — I think I can add a useful controlled data point, because I’m exactly that roaming case.
Setup: FP4 (FP4.QREL.15.19.1, A15, May 2026 security patch), used as a motorcycle navigation device across Colombia — so constant handovers across patchy mountain coverage on a roaming/local eSIM, very different from a stable home network.
What I observed:
Spontaneous reboots (always reboots, never stays off), sometimes several within 10 minutes while riding, sometimes none for hours.
Airplane mode ON + navigating from offline GPX = zero reboots, reproduced across multiple full riding days, including cold weather. Radio off, GPS still works, phone stays up.
Radio ON in weak/patchy coverage = reboots return — and crucially reproduced stationary, on foot, in a low-signal area. So it’s not movement, vibration, mount, or heat.
In an area with no signal at all (high-altitude páramo), no reboots either — consistent with the trigger being registration/re-registration attempts in marginal signal, not the radio simply being on.
Diagnostics (via ADB, unrooted): boot reason is a bare reboot — no kernel_panic, no thermal shutdown, no tombstones/SYSTEM_LAST_KMSG, numLastResortWatchdogTriggers=0. Thermal readings were normal (skin ~38–40 °C, well under shutdown thresholds). So the usual suspects (panic, heat, runaway process, vibration) are ruled out on this device.
This lines up with the “particular transmitters / certain networks” theory in the thread, but sharpens it: the airplane-mode elimination isolates it to the radio/modem stack when it’s registering in marginal or unfamiliar-network conditions. Workaround that’s held reliably for me: airplane mode + offline GPX when in poor coverage.
Happy to share the raw dropbox/dumpsys details if useful.
(This post was drafted by Claude Opus, which also assisted with the ADB diagnostics; all tests were run on my own device.)
Dear Yvan,
I hope your tests info are shared with the developpement team :smiley:.
