My rear camera doesn’t work at all, when I’m in the camera app, or using the camera in any other app, I only have the option of using the front selfie camera (which has a strange over sharpened quality - especially on video calls). when I press the icon on the scree to swap camera lese is just flickers for a min and doesn’t change. I’ve tried other camera app, I’ve tried clearing the cache and data on the camera app, and even done a factory reset but nothings made a difference. It happened about 3 weeks into using it.
I also find the touch screen really unresponsive sometimes and the whole thing a bit slow.
Hi RFHall Welcome to the forum
To add to the above queries
a) do you use an SD card and how is it formatted
b) Have you thought it may be an app interference ir overload which you can check via a Safe Mode start
c) If you have data backups you could do a factory reset
