Question about data transfers on Fairphone 5 via universal serial bus (USB)
Hello, can anyone on Fairphone 5 running Android 15 verify if connecting via a universal serial bus to another device for data transfers asks for additional biometric/password verification before accepting the device? Or do you just need to press
Yes
and that’s it? What is the process?
When I connect my FP5 to a windows computer:
  1. A system message says, that my FP ist charging. Tap to get more oprions.
  2. USB settings screen: Select Data Transfer (Datenübertragung)
  3. You have to enter your PIN or finger print.
  4. FP is connected and you can access storage via Explorer (or any other program).
