Qualcomm Aptx bug?
I just connected my Bluetooth headset and it works fine without aptx enabled, HOWEVER enabling it seems to cause a bug which I am not sure is related to a bug I seen here last year regarding the aptx.
When enabled it seems to pause and unpause my audio every second.
My headphones definitely support aptx and are known working with other devices using the aptx codec.
Does anyone know if this is a known issue?
How do you enable, isnt that happening automatically? When I connect mine I just see a pop up showing aptx HD is used…
Else which headphones and which aptx codec exactly?
When I paired it, it did automatically use it, however I turned it off manually in the settings.
Like so.
Okay nevermind, an update came through updating from android 12 to 13 and it no longer is broken.
Then your phone is not at all up to date, so def. check for further updates to ensure the most recent is installed.
