Problems with intallation any OS on my FP
A few hours ago I think I bricked my Fairphone 5 by trying to install the /e/OS. I downloaded the latest 2.7 official IMG zip and used the guide and Git Bash to do the install but it always freezes at
Sending sparse 'super' 1/6 (762373 KB)             FAILED (Error reading sparse file)
ERROR: Could not flash the super partition on device
I’ve tried changing cables and a lot of other things I’ve seen on the forum but nothing has worked. Right now I cannot load into any OS but I can reach the Recovery for /e/OS. My goal is to either finish the installation or somehow reinstall the original OS.
The bootloader is still unlocked
I fear, you might have stumbled on the problem which bricked my device 10 months ago:
"The FP5 comes with an anti-rollback feature. Google Android anti-roll back feature is supposedly a way to ensure you are running the latest software version, including the latest security patches.
If you try installing a version of /e/OS based on a security patch that is older than the one on your device, you will brick your device. Click on Details below for detailed information"
https://doc.e.foundation/devices/FP5/install
If this is the case, you have no choice than sending the FP5 in for repair. I am sure others will give you some commands to test, if you can get your device back running or if you have to send it in.
As the bootoloader is unlocked it should be possible to just reinstall FPOS. Anti rollback is only relevant when you lock the bootloader
You should be able to boot into fastboot? This means you could just reinstall FPOS
I confirmed that the previous android patch was done in August in 2024 and the /e/OS version I was moving to was released January 11th 2025.
When I tried to reinstall FPOS
@DESKTOP-CC3GG5H MINGW64 ~/Desktop/FP5-UT2H-factory/FP5-UT2H-factory
$   chmod +x flash_FP5_factory.sh && ./flash_FP5_factory.sh
*** Fairphone 5 flashing script ***
INFO: The procedure will start soon. Please wait...
INFO: The package type is "user-factory"
INFO: You are using MinGW on Windows
INFO: Validating the integrity of the package.
      This might take a while. Please wait...
INFO: Validation complete.
WARNING: Flashing this image wipes all user data and settings on the phone.
         It will also remove the Google factory reset protection.
         Are you sure you want to continue?
         Type "Yes" (case sensitive) and press enter to continue: Yes
INFO: Looking for connected device(s)...
INFO: One Fairphone 5 in fastboot mode found (serial number: 95c652b6).
INFO: The device is fully unlocked.
INFO: Proceeding to flash the device.
INFO: flashing partitions...
Sending 'abl_a' (152 KB)                           OKAY [  0.006s]
Writing 'abl_a'                                    OKAY [  0.002s]
Finished. Total time: 0.019s
Sending 'abl_b' (152 KB)                           OKAY [  0.005s]
Writing 'abl_b'                                    OKAY [  0.001s]
Sending 'aop_a' (203 KB)                           OKAY [  0.006s]
Writing 'aop_a'                                    OKAY [  0.002s]
Finished. Total time: 0.031s
Sending 'aop_b' (203 KB)                           OKAY [  0.006s]
Writing 'aop_b'                                    OKAY [  0.002s]
Finished. Total time: 0.021s
Sending 'apdp' (13 KB)                             OKAY [  0.002s]
Writing 'apdp'                                     OKAY [  0.002s]
Finished. Total time: 0.022s
Sending 'bluetooth_a' (3388 KB)                    OKAY [  0.073s]
Writing 'bluetooth_a'                              OKAY [  0.009s]
Finished. Total time: 0.096s
Sending 'bluetooth_b' (3388 KB)                    OKAY [  0.073s]
Writing 'bluetooth_b'                              OKAY [  0.012s]
Finished. Total time: 0.099s
Sending 'cpucp_a' (182 KB)                         OKAY [  0.006s]
Writing 'cpucp_a'                                  OKAY [  0.002s]
Sending 'cpucp_b' (182 KB)                         OKAY [  0.006s]
Writing 'cpucp_b'                                  OKAY [  0.002s]
Finished. Total time: 0.020s
Sending 'ddr' (20 KB)                              OKAY [  0.002s]
Writing 'ddr'                                      OKAY [  0.001s]
Finished. Total time: 0.014s
Sending 'devcfg_a' (52 KB)                         OKAY [  0.003s]
Writing 'devcfg_a'                                 OKAY [  0.002s]
Finished. Total time: 0.023s
Sending 'devcfg_b' (52 KB)                         OKAY [  0.003s]
Writing 'devcfg_b'                                 OKAY [  0.007s]
Finished. Total time: 0.029s
Sending 'dsp_a' (65536 KB)                         OKAY [  1.393s]
Writing 'dsp_a'                                    OKAY [  0.136s]
Finished. Total time: 1.541s
Sending 'dsp_b' (65536 KB)                         OKAY [  1.411s]
Writing 'dsp_b'                                    OKAY [  0.099s]
Finished. Total time: 1.523s
Sending 'featenabler_a' (84 KB)                    OKAY [  0.004s]
Writing 'featenabler_a'                            OKAY [  0.012s]
Finished. Total time: 0.028s
Sending 'featenabler_b' (84 KB)                    OKAY [  0.004s]
Writing 'featenabler_b'                            OKAY [  0.005s]
Sending 'hyp_a' (3601 KB)                          OKAY [  0.078s]
Writing 'hyp_a'                                    OKAY [  0.012s]
Finished. Total time: 0.105s
Sending 'hyp_b' (3601 KB)                          OKAY [  0.078s]
Writing 'hyp_b'                                    OKAY [  0.021s]
Finished. Total time: 0.112s
Sending 'imagefv_a' (64 KB)                        OKAY [  0.003s]
Writing 'imagefv_a'                                OKAY [  0.004s]
Sending 'imagefv_b' (64 KB)                        OKAY [  0.003s]
Writing 'imagefv_b'                                OKAY [  0.005s]
Sending 'keymaster_a' (261 KB)                     OKAY [  0.008s]
Writing 'keymaster_a'                              OKAY [  0.003s]
Sending 'keymaster_b' (261 KB)                     OKAY [  0.007s]
Writing 'keymaster_b'                              OKAY [  0.009s]
Finished. Total time: 0.030s
Sending 'logfs' (16 KB)                            OKAY [  0.002s]
Writing 'logfs'                                    OKAY [  0.001s]
Sending 'modem_a' (184796 KB)                      OKAY [  4.000s]
Writing 'modem_a'                                  OKAY [  0.561s]
Finished. Total time: 4.593s
Sending 'modem_b' (184796 KB)                      OKAY [  3.954s]
Writing 'modem_b'                                  OKAY [  0.619s]
Finished. Total time: 4.584s
Sending 'multiimgoem_a' (13 KB)                    OKAY [  0.002s]
Writing 'multiimgoem_a'                            OKAY [  0.002s]
Finished. Total time: 0.015s
Sending 'multiimgoem_b' (13 KB)                    OKAY [  0.002s]
Writing 'multiimgoem_b'                            OKAY [  0.002s]
Sending 'qupfw_a' (55 KB)                          OKAY [  0.002s]
Writing 'qupfw_a'                                  OKAY [  0.003s]
Finished. Total time: 0.018s
Sending 'qupfw_b' (55 KB)                          OKAY [  0.003s]
Writing 'qupfw_b'                                  OKAY [  0.012s]
Finished. Total time: 0.025s
Sending 'rtice' (261 KB)                           OKAY [  0.013s]
Writing 'rtice'                                    OKAY [  0.007s]
Sending 'shrm_a' (44 KB)                           OKAY [  0.002s]
Writing 'shrm_a'                                   OKAY [  0.011s]
Finished. Total time: 0.024s
Sending 'shrm_b' (44 KB)                           OKAY [  0.002s]
Writing 'shrm_b'                                   OKAY [  0.011s]
Sending 'storsec' (20 KB)                          OKAY [  0.002s]
Writing 'storsec'                                  OKAY [  0.002s]
Sending 'study' (240 KB)                           OKAY [  0.007s]
Writing 'study'                                    OKAY [  0.001s]
Sending 'studybk_a' (240 KB)                       OKAY [  0.006s]
Writing 'studybk_a'                                OKAY [  0.002s]
Sending 'studybk_b' (240 KB)                       OKAY [  0.006s]
Writing 'studybk_b'                                OKAY [  0.002s]
Sending 'tz_a' (3713 KB)                           OKAY [  0.080s]
Writing 'tz_a'                                     OKAY [  0.018s]
Finished. Total time: 0.109s
Sending 'tz_b' (3713 KB)                           OKAY [  0.080s]
Writing 'tz_b'                                     OKAY [  0.023s]
Finished. Total time: 0.113s
Sending 'uefisecapp_a' (122 KB)                    OKAY [  0.004s]
Writing 'uefisecapp_a'                             OKAY [  0.005s]
Sending 'uefisecapp_b' (122 KB)                    OKAY [  0.004s]
Writing 'uefisecapp_b'                             OKAY [  0.004s]
Sending 'xbl_a' (3602 KB)                          OKAY [  0.078s]
Writing 'xbl_a'                                    OKAY [  0.015s]
Finished. Total time: 0.104s
Sending 'xbl_b' (3602 KB)                          OKAY [  0.078s]
Writing 'xbl_b'                                    OKAY [  0.013s]
Finished. Total time: 0.102s
Sending 'xbl_config_a' (220 KB)                    OKAY [  0.006s]
Writing 'xbl_config_a'                             OKAY [  0.004s]
Sending 'xbl_config_b' (220 KB)                    OKAY [  0.006s]
Writing 'xbl_config_b'                             OKAY [  0.004s]
Sending 'boot_a' (98304 KB)                        OKAY [  2.083s]
Writing 'boot_a'                                   OKAY [  0.318s]
Finished. Total time: 2.414s
Sending 'boot_b' (98304 KB)                        OKAY [  2.084s]
Writing 'boot_b'                                   OKAY [  0.314s]
Finished. Total time: 2.412s
Sending 'dtbo_a' (24576 KB)                        OKAY [  0.521s]
Writing 'dtbo_a'                                   OKAY [  0.120s]
Finished. Total time: 0.653s
Sending 'dtbo_b' (24576 KB)                        OKAY [  0.520s]
Writing 'dtbo_b'                                   OKAY [  0.141s]
Finished. Total time: 0.674s
Sending sparse 'super' 1/9 (726508 KB)             FAILED (Error reading sparse file)
ERROR: Could not flash the super partition on device 95c652b6.
ERROR: Please unplug the phone, take the battery out, boot the device into
ERROR: fastboot mode, and start this script again.
ERROR: (To get to fastboot mode, press Volume-Down and plug in the USB-C)
ERROR: (cable until the fastboot menu appears.)
ERROR: Aborting now (press Enter to terminate).
the download still fails when it reaches the “Sending sparse ‘super’”
critical is unlocked as well?
Edit what PC system do you use?
I’m Currently using windows 10
And critical is unlocked?
Maybe its still a fastboot issue do you use official google adb/fastboot platform tools?
Edit and maybe its still a cable issue
I did Unlock Critical, and i am using the platform tools linked in the official /e/OS installation guide in combination with Git Bash to make the installation.
Is there a fast boot command I can use to show you the Unlock status
$ fastboot oem device-info
(bootloader) 	Device tampered: false
(bootloader) 	Device unlocked: false
(bootloader) 	Device critical unlocked: true
(bootloader) 	Charger screen enabled: true
(bootloader) 	Display panel:
(bootloader) 	Adb enabled: false
OKAY [  0.069s]
Example from a FP3.
Here is what I have
\Desktop\platform-tools>fastboot oem device-info
(bootloader) Verity mode: false
(bootloader) Device unlocked: true
OKAY [  0.005s]
Finished. Total time: 0.005s
For me it looks like a read error of the source file (sparse file format).
You are using a Windows environment: Are you sure using the correct android tools version ?
Maybe you should boot your PC/Notebook with a Ubuntu (or any other Linux Distribution) live system and flash your FP5 using the android tools of the linux distribution.
I installed Ubunto onto a flash and followed the install steps again on that OS System and everything went smoothly. I believe there’s some issue with my android tools on Windows.
When installed Ideos on my FP4 I also had problems until I updated the USB drivers on my Windows 10 notebook. With the updated USB drivers all went smoothly then.
Were you able to re-lock the bootloader too? Or did you leave it unlocked?
