I found a problem in the web shop of Fairphone:
The phone number can max. be 10 characters.
My mobile phone number in international format is: +49 163 xxxxxxx
(13 characters without the blanks, it is too long)
When I leave away the country code, then I have: 0163 xxxxxxx
(11 charactrers without the blanks, still too long)
So I am forced to write my number like this: 163 xxxxxxx
(10 charactrers) but here nobody will be able to contact me, because the caller has to know that this is a number in Germany and that there is a 0 at the beginning needed when you call from Germany
So I suggest you allow a longer number (at least 15 characters).
@formerFP.Com.Manager I know that you are from the Fairphone team, so I am taking you in CC here.
Best regards
OLLI
Edit
Even my phone number from home is too long:
+49 89 xxxxxxxx (also 13 characters, same problem like above)
And my office number is also too long:
+49 89 xxxx xxxx (also 13 characters)
Seeing as youâre already required to select your country when ordering, it seems to me that the country code isnât necessary. I canât even put in my Dutch phone number (00316XXXXXXXX) if I use a country code - so I think you can just leave off the +49 (or 0049).
I agree with you that probably country code can be left out. But 10 digits is still not enough! E.g. in my case phone numbers are still 11 digits. And the weird thing is that it seems this limit has not always been there: my 11 digits are already configured in my FP shop accountâŚ
Not a good solution. But it might be a workaround: if you create an account while ordering you can later change the phone number to a longer one in the address setting of the accountâŚ
Clearly this character limit needs to be corrected - and once fixed, if the country code is still to be left out, that should also be made clear in the form. Iâm so used to typing out my phone number country code and all that Iâd probably run into the same issue as the OP if I ordered something.
So leaving out the country code is not solving the problem.
I already did this (directly after ordering my Fairphone 3+).
In my profile even the full number with blanks is allowed like: +49 163 xxxxxxx
But thank you for your feedback, @Volker
AFAIK, there is an limit of 13 digits for international phone calls. This includes the two or three digit country code and the ten digit phone number. It does not include any prefixes like â+â (which translates to â00â, â011â, etc depending on your provider/country of origin) or the â0â used in many countries to signal an area code as in 0163.
So your phone number is not 0163 xxxxxxx but âareaâ code 163, local number xxxxxxx.
I have seen phone numbers with 11 or maybe even twelve digits in Germany, but I believe they were an artifact created by using too many digits on a private exchange.
In the international telephone network, the format of telephone numbers is standardized by ITU-T recommendation E.164. This code specifies that the entire number should be 15 digits or shorter
