Problems when placing calls
For some time, when I make a phone call, I have (often or always) been receiving the error message “My contacts is not responding”. I can tap either wait or close - it doesn’t seem to make a difference. The message shows up at the end of the call.
In addition, when I try to make a call, I sometimes get a message saying “The call wasn’t sent”. There is no ring sound to be heard anymore at that point. If I repeat the call immediately, though, the call is placed twice: I end up hearing both the person answering one call, and their answering machine or the “busy” sound for the other call!
I have FP Open OS installed; I did the last update yesterday but it didn’t change anything.
Any ideas? Thank you!
Sounds like a combination of:
https://forum.fairphone.com/t/two-sim-cards-cant-make-receive-calls-when-both-are-turned-on-workaround-wait-5-seconds/12118?u=paulakreuzer&source_topic_id=26405
and:
Well, yes… Almost. I have only one SIM card and I don’t cancel the calls myself (I think cancelling a call still works, luckily). The calls are indicated as “not sent”, so I try again. Which also means that the workarounds that I have read about don’t apply.
I think the message about the contacts is probably a separate issue (it shows up on the screen during calls, too). Has anyone else seen it?
