Problems after updating android 9 and 10 and screen problems
Same here. Frequency decreased over time though.
(Haven’t updated to Android 10 yet.)
Hi, I have the reboot problems, the SD card problems, the battery doesn’t last long… but now also, after updating to android 10, I keep getting an error with the download manager. Does anyone else have this problem? I’m a militant against programmed obsolescence, but FP2 is putting me to the test.
What is the exact error message, and in which situation do you get it?
And are you using Fairphone OS or Fairphone Open OS?
Just after switching on, the error message is “download manager keeps stopping”
I cleared the cache and data from storage of the download manager, and the problem seems to be gone, the error message is not appearing. But still, I have problems downloading files from internet.
Hello. I haven’t had a problem with the download manager. Sometimes it’s hard to be militant, you’re right. At the moment I think he is worth it for everything behind the project. I also hope that the newer models will have fewer problems.
Coming back to …
Did you make sure your SD card is formatted as external/portable, not as Internal Storage? (See hints earlier in this topic or sdcardguide.)
Thank you, yes, I think that it’s the problem
