Problem with the "google" storage
Hello everyone,
I gave a problem with the “google” storage. So I have deconnected the google save for picture and stuff . But the google storage is still full. The probleme is, I have deleted stuff and I’m 80% full now and my fairephone refuse to take picture because “there is not enough space”. But I do have space…
And it changes nothing that I’m deleting stuff.
Thanks !
I’m a little bit confused, because taking pictures should primarily use the local storage, not the Google Cloud so taking pictures is possible even without an internet connection.
Do you happen to have a SD card installed in your FP3 and use it as internal memory expansion?
I actually don’t have an SD card but I’m gonna try it.
Thank you !
That wasn’t my intention. If you dare using a SD card, formatted as internal memory expansion, inconsistencies while storing data might happen. So if you don’t have a card, that can’t be the reason for your problems.
The 80% you mentioned, are used internal memory or from you Google account?
although I’d never use google storage, are you sure you have really deleted there and not moved content to its wastebox. Only guessing that google storage have one as you normally have on Windows, Linux and so on.
Additionally I guess that you use google fotos on your phone. If you delete pictures from there, they are first marked for deletion (like a waste box) and later (after 30 days) they are finally deleted, freeing the space on your device. When using e.g. Gallery (from FDroid store) you can decide on every deletion job, if you delete or move to wast box.
