I have bought a FP2 to have spare parts as mine have screen pb.
The one I have bought does not receive well (worse than mine), so I suppose there is a pb with antenna.
Do you have some advice to change antenna ? Is this this part I have to change ?
It is this part. If you need to take it off, you’ll have to remove the grey protective shield first. Be very careful when disconnecting the cable from the motherboard, and take it out carefully, having disconnected the other end. That’s about it.
