Problem to unlock Device State with fastboot command
I’m posting this thread because I’m currently stuck with some problems.
I installed /e/OS on my Fairphone 3 but now I want to going back to Android. I followed the steps like disable the secure boot but I’m unable to unlock the device state with “Fastboot”.
I can list the device with “adb devices” command, I can also reboot the device with “adb reboot bootloader” unfortunately when I want to use the command “fastboot oem unlock” I only have the answer, “< waiting for any device >”.
I launch it with cmd with admin rights. I have the android drivers installed on my computer but it doesn’t help in any way.
Do you have any idea to solve my problem?
Thanks in advance for your answers =)
Ok, Windows it is. In case of Windows 10 you might find some hints here …
There’s also this … even if over time it turned out to be more of an ADB/MTP repair than a fastboot repair, but who knows …
Excuse-me for my English.
I have the same problem than Zhennefi : my phone is locked Fastboot mode. Than him, the screen indicates in red “Device State : locked”.
I have followed your instructions above, to install Android SDK Platform Tools. But, it is always locked.
In the command prompt (Power Shell), I type « adb devices », the device is recognized. Then, when it is in fastboot mode, it indicates « Waiting for any device ».
Have you an idea to resolve our problem ?
Thank you in advance.
So My problem is solved!
None of the solutions worked on my computer. I went at my parents house and used their computer and it works it seems I had an issue for doing this task on my computer. I used the second link from @AnotherElk to solve this problem.
By the way thanks for your help @AnotherElk =)
https://forum.fairphone.com/t/trying-to-install-e-os-on-fp3-but-it-hangs-on-fastboot-on-windows-10/61544/2
