Hello, do anyone of you have a peoblem to connect to 5g or 4g datas without wifi ?
Hi, the issue does not seem too common on the forum. But, the details matter.
Could you tell us your provider?
Hello Meaghan, I’m un France, m’y provider is SFR.
Hello
thank you for getting back to me. I can see you have also found the relevant topics in French.
My limited knowledge would suggest the issue with the provider/settings (APN alike). Could you test the SIMcard from a different provider?
Before testing another SIM, def. check the APN is set-up correctly, because yes, normally thats the reason why mobile data isnt working, assuming mobile data is enabled in general.
Thank you Meaghan, it seems that it works now, thanks d’or tour help
Regards
