Maybe you should look here:
Experienced users do not need longer than 15-20 min. to flash a Fairphone within a Linux shell.
Sounds nice, we could try to organize one.
OK jâai âouvrir dans power shellâ
sur la commande âfastboot devicesâ jâai comme rĂ©ponse
A209MGFS0202
jâimagine que ca veut dire que mon FP3 est bien reconnu par lâordinateur
oui câest ca
cool. Et si il nâya pas de petit triangle a cote ca veut dire que le telephone est bien connecte et reconnu par lâordinateur
Mince⊠je vais continuer en anglais au cas ou dâautres personnes veulent se joindre a la conversation.
It seems that the installer bloks itself because the phone was not finish with the initial installation, and is now in between or does not have all the necessary files to continue.
Youâve tried to just start the phone earlier right?
If it is not working I can see a few options:
I would try those options in this order. You could retry to install e/os after the second option too.
I have to go now, I hope you will manage to tackle this. And others can help you ![]()
OK, merci beaucoup pour ton aide.
Je vais essayer ces solution dans cet ordre. Bonne journée.
Ca a marché
Merci Ă tous pour vos contributions.
Parfait le guide dâinstallation manuel.
