Possible to replace motherboard of FP1 with FP1U? - Yes
i habe an FP1 and my usb slot is broken, so i want to replace the motherboard. But there is no motherboard for FP1 available here. So can i replace it with the motherboard of FP1U?
If nobody else has tried this, I’d contact support. They will know for sure.
I have the same idea. I asked the support and i’m waiting for the response.
I can’t find the post atm but I’m pretty sure I remember a post by a FP employee ( I think it was @Marco ) who explained that all parts were interchangeable. He also posted a picture pointing out the only difference between FP1 and FP1U’s hardware and it was something like a corner of a board was rounded differently or such.
Wow, I was wrong on many levels. Here is the post I was talking about:
PS: Based on the pictures I’d say that FP1 can be “upgraded” but FP1U can’t be “downgraded”.
I have a answer for the support:
Leontine (Fairphone)
Feb 3, 12:44
Dear Dietmar,
Yes you can!
All the best,
Leontine
D
Feb 3, 12:02
i have an FP1 and my usb slot is broken, so i want to replace the motherboard. Can i replace it with the motherboard of FP1U?
Thanks in advance!
