English
✏ Porting TWRP recovery
recovery
wiki
twrp
Tags: #<Tag:0x00007fefbfb4adc8> #<Tag:0x00007fefbfb4ac60> #<Tag:0x00007fefbfb4aad0>
#125
Its interesting that FPOSOS comes with TWRP.
Does anyone know if the version that is distributed with FPOSOS was compiled by Fairphone or if they just used the version provided in this thread?
If it was compiled by Fairphone, is there a way to extract TWRP and use this version on a FPOS device?
Thanks!
#126
Yes it is the same Version 2.8.7 . Only starting animation is different. If you like, you can extract it from the image.
Lg ivi
#127
First of all: thank you so very much for all this hard work, TWRP, Rooting and XPosed worked beautifully for me :sunny: D
Now question on updating: in the guide on howto update (have to be manual), it’s said that XPosed must be reflashed after updating; if I do so, will I loose all the configuración made to XPrivacy and GravityBox ? That would be kinda nightmare …
Any ideas? Thank you so much!
#128
Maybe this is helpful for you:
#129
No!
and some letters more, because the post must not have less then 20 new characters. Sigh!
Spielmops
#130
Thanks OuinOuin and Max_S for your efforts!
@OuinOuin did you have a chance to test your TWRP 3.0 version with an encrypted user data partition? Could TWRP decrypt it?
#131
Dit anyone tried to use twrp from FPOSOS on FPOS and if so, what are the differences/advantages?
#132
I just tried to flash the twrp image from the above dropbox link as well as the one from the fposos image. In both cases the flashing was reported to be fine but obviously the recovery image I have is still the stock. So I assume nothing was really flashed after all.
I assume the problem is that my phone is not rooted so far. I could not find any explicit indication of this requirement in the thread, however. Am I mistaken and I just missed it?
Otherwise: Could someone please confirm if rooting is required to flash the new recovery image? If so: It would be good to include this explicitly in the instructions above.
#133
No, it isn’t required. I also flashed twrp without having root.
#134
Ok, thanks for the clarification.
So I’m wondering what kind of problem I have then.
The fastboot flash recovery <recovery.img> command does not produce any errors - but I end up with the original recovery anyway…
Is there some other signature lock or something that has to be disabled first?
I also tried to boot the recovery via fastboot boot <recovery.img> but that just gives me a signature error after the transfer is complete. On the other hand I’m not sure if that would work anyway.
#135
What do you do after the fastboot? Boot into the OS proper and reboot to recovery, or do you immediately boot into recovery? Don’t know for fairphone’s O’s, but some systems restored their original recovery if they found a modified one. Only if you immediately reboot into recovery after flashing the recovery was “fixed”
#136
Thanks for the hint!
Just to be sure I tried again with Windows (instead of Linux). But that did not change anything.
I then made sure I boot immediately into recovery instead of letting the phone boot normally. And it actually worked!
I then rebooted the phone again and tried which recovery I will get afterwards: Turns out it is back to stock. So there’s clearly a restore going on there. I just wonder why this is not documented anywhere. Is it a new “feature” of the 1.2.8 FPOS? Or it just doesn’t happen once you rooted it?
So in case you have the same problem: Do NOT follow the instructions to fastboot reboot after the flashing. Instead you have to turn off your phone and get into recovery right away.
#137
Hey, I am interested in the stock recovery.img, can you give it to me?
#138
At the end of the first post are several links, the one with the “18” in front seems to be the original recovery-image.
#139
You can always get an original recovery.img from here (‘Flashable Images’, not yet updated to 1.4.2 but shouldn’t care ;))
#140
Thanks, actually I extracted the one of FP Open OS and it seems to work :slight_smile:
#141
where can I find the preinstalled TWRP at FP OSOS?
I wanted to install the XPosed Framework on my FP2 and think that the TWRP is also very interesting.
My FP Open Version is 16.05.0.
#142
Simple. Just shut down the phone, and then switch it on again while pressing vol+. When the phone started, release the power on button and a few seconds later release vol+. This will take you to the recovery
#143
Thank you, that worked :slight_smile:
#144
Thanks for all the hard work and all the information - a few questions, yet:
Q1: can I boot into the recovery without flashing it to the device?
As @mde has mentioned, I also get an error when trying to fastboot boot into the recovery.img. This makes me a bit nervous and keeps me from flashing the image to the device, at the moment :slight_smile:. Here’s what I get:
D:\...\>fastboot.exe boot twrp-recovery.img
downloading 'boot.img'...
OKAY [  0.501s]
booting...
FAILED (remote: bootimage: incomplete or not signed)
finished. total time: 0.506s
Same question, different wording: does this error only occur when trying to “boot” into the recovery.img and should flashing it work properly? Or will “flashing” it to the device produce the same problem (or real one then…)?
Q2: which one is the TWRP recovery.img that I should use for FP2 today?
I suppose the “newer” one from @OuinOuin’s post is the one to go for? (or are there any more up to date TWRP versions for the FP2 in the meantime?)
Q3: could a broken recovery image be restored again?
If I flash the TWRP recovery.img and in case it didn’t work, is it possible to boot into fastboot mode and flash the original recovery again? I would I end up with an entirely messed up (bricked?) phone in case something went wrong here?
Thanks already for your efforts! :slight_smile:
