Playground: Features of this forum
Question:
How can I type aachen.fairphone.community as a plain, non-hyperlinked text (and without grey background)?
Not that elegant, but possible: HTML (leave out the three blanks): < font> Text< /font>
Just putting the closing tag < /font> at the end actually does the trick, too:
aachen.fairphone.community (No, will not work when another hyperlink precedes this in the same paragraph
Just use the html code for one of the separators rather than a full top
I found some discussion about this in the Discourse forum.
So <span>aachen.fairphone.community</span> should work:
Thanks for your approaches. I’ll try them out.
Update: It seems the problem is with the preceding link.
fairphone.com | aachen.fairphone.community (using accent keys `` )
fairphone.com | aachen.fairphone.community (using amoun’s period code)
fairphone.com | aachen.fairphone.community (using hirnsushi’s span tag)
To refer to the “use case”, it’s the Contact line below the photo here that is concerned: 🇩🇪 🇬🇧 Fairphone Community Aachen :community_round: 10 Mai 2022
I might have to consider putting all the links in that line into a href HTML tags.
Update 2: Dang, that doesn’t help either :frowning:
I just tried aachen.fairphone<span>.</span>community and that seems to work:
Contact: E-Mail | Mastodon | Twitter | Instagram | aachen.fairphone.community
Ingenious :laughing: Thanks!
A simpler way perhaps?
aachen\.fairphone.community → aachen.fairphone.community
Edit: mistake
I have not read the whole thread, it’s a bit too big. But I can help out here a bit. The past week I took some days off from work and worked on a map for another forum. I was inspired by the FP map and I made it work with the JSON output.
I’ve created this simple plugin to add custom fields:
I’m also working on a few other improvements. Once I’m satisfied of my map, I’ll take the time to merge my improvements back into the FP map :tada:
Reference: Accredit Fairphone in a modified version of the Fairphone map + 'heaven' listings? · Issue #15 · WeAreFairphone/fpangels-hp · GitHub
In any case, this is my version of it. I first need to a break from this stuff :stuck_out_tongue:
It seems there is no longer a difference between bold and double bold.
**bold**
****double bold****
Maybe an anomaly that it ever existed
I checked it in the sandbox environment with the Arial font and default Discourse CSS. I didn’t see any difference.
What a beautiful link!
[What a beautiful link!](https://fairphone.community "Link titles can be created in Markdown, too")
Me too! Hello @discobot
Hi! To find out what I can do, say @discobot display help.
I currently know how to do the following things:
@discobot start {name-of-tutorial}
Starts an interactive tutorial just for you, in a personal message. {name-of-tutorial} can be one of: tutorial, advanced tutorial.
@discobot roll 2d6
:game_die: 3, 6
@discobot quote
:left_speech_bubble: What you give is what you get. — Byron Pulsifer
@discobot fortune
:crystal_ball: You may rely on it
@discobot start tutorial
@discobot start advanced tutorial
