Good news and bad news, I got ahold of another phone and same problem, so it’s not the fairphone. But is the system update stored on google servers? If so the issue has to be with google servers.
Not Google’s fault. Turned off the wifi and the speed came back. I don’t understand why such a reaction to wifi, I’m using my laptop and the wifi is perfectly fast.
Now question is how to download the system update on a mobile network without wi-fi? It says waiting for unmetered wifi?
Maybe the hint about “waiting for unmetered wifi” is worth a try.
If I understood it correctly a metered connection is restricted to avoid costs. If you have unlimited wifi try this:
Have a look at your FP3’s wifi settings and open the cogwheel to the right of your wifi name. Scroll down to “Advanced” an see if you can change the Metered option. By default it is set to automatically detect. If that doesn’t work, change it to unmetered.
If that solves your problem it raises the question why your device automatically recognizes your home wifi as metered. Is this a router setting?
Thanks but metered or unmetered, the wifi is unusable to download apps, update apps or download system updates. Which is strange because it is super fast otherwise.
Concerning the problem somehow I managed to download it through mobile network, I just kept clicking to resume and it gave in.
Luckily I have enough data allowance so I can live with mobile data downloads.
This issue is not rare it seems as I have done some research and a lot of people had/have this issue and the reason was not identified.
If it is a router I have no knowledge to screw around with it.
It must be ISP limiting download speed from google servers. Oh well.
