So, thanks to all for the support, but still the issue is not sort out.
I did transfer the DCIM from the phone memory to the SD-Card but still, if the SD-Card is read from the phone there is no track of the photos.
Once I move the SD-Card in the computer then I get to see all of them.
So, there is definitely something to do with the phone, I don’t know what, but must be something there. Are missing more than 700 pics…not few…
So I would love someone of the Fairphone team to jump out with a solution, please.
Get to transfer all the photos all the time, is not that exciting.
Ah! If I try to copy the new directory with all the photos in the phone, nothing happens! It is just the same!
Can you provide some screenshots? I assume there is a subtle difference for those missing photos (permissions, size, format, filename, etc.) when compared to those that are seen from the PC.
What might help are screenshots of
image details of a photos that works and one that doesn’t in the gallery app
folder view of the same photos on the phone
folder view on your PC when connected to the phone via USB
folder view on your PC when you take the SD card out of the phone and inserted in the PC
They don’t really hang out on the forum much, so you’ll either need to file a support request (#contactsupport) or use the #bugtracker to get their attention.
Also, this problem is not Fairphone specific (Google’s own devices are also affected), which makes me think that this a general Android issue. Generally a reset of media storage solves it (though suggestions vary with regards to clearing cache or data + cache and the necessity of a reboot afterwords), so this could be a slightly different issue.
I’m using MyPhoneExplorer http://www.fjsoft.at/de/ to synchronize Android phones and transfer pictures, movies or other files. That always works for me. It possible to use it via Bluetooth or WLAN too.
I got confused when I plugged my phone into my pc and it said there was only 1gb of free space but checking individual folders in “internal storage” on pc only showed a fraction of the actual used up space. I wondered what was using up all that storage…
I was trying to back up my pictures, so I copied DCIM to my pc manually. Then I realized the folder was only 3gb but my phone claimed there were 8 gb of images using up storage. also the music folder showed 0 files but there was plenty of music (at least another 8gb)… I foolishly followed the suggestion from the other thread (deleting DCIM folder and getting the camera app to recreate the folder) of course that did not work and I lost all 4gb of missing pictures. even after a reboot my camera folder now really is empty…
