Phone not connecting to mobile network - antenna issue?
Hello, my phone keeps having issues connecting to my mobile network. I try switching it on and off, and eventually after 30 to more minutes, it finally gets it.
I am not sure if the antenna is an issue and if it can be repaired?
It has the same problem whether I use a physical SIM card or a esim.
No issue on wifi
Thanks a lot in advance for your help!!!
Hi, welcome to the forum. Have you tried the suggestions on this page?
https://support.fairphone.com/hc/en-us/articles/9498003764113-Troubleshoot-the-mobile-data-connection
I know the article specifically mentions mobile data issues, but it’s worth trying for general GSM issues as well.
Thanks a lot for looking into this!
I have tried pretty much everything that article said… created a new APN, selecting network manually…
Nothing really works. It works sometimes. Can’t really find a pattern. it will take forever to reconnect after I lost network (I live in a remote area) or after plane mode …
Any other idea?
:folded_hands:
hello
have you also tried changing the network type?
If you are still not connected, try different connection protocols (5G/4G/3G/2G).
Does it make any difference?
Are they both from the same network operator?
Hello @Meaghan
Changing network type first do anything…
And I have the same issue with sim and esim from different networks.
If I try to manually choose the network, it sees it but doesn’t connect to it.
And then suddenly it connects.
I’m not sure if it’s a software or hardware problem …
Perhaps this helps; set your SIM card to 4G/3G/2G.
None of these work…
has anyone tried to fix/replace the antenna in their fairphone?
I have the same issue, exept that the phone never connected again after updating to the newest Android 15. I tried everything that is mentioned here.
The SIM Card is recognized, but the phone shows no telephone number.
The solutions I tried:
-changing the network type to 4G or 3G
-using an eSIM, using a new physical SIM
-Flight Mode On/Off
-changing the APN to Standard (German O2)
-starting the phone in failsafe mode (Abgesicherter Modus in German)
Has anybody another idea, exept sending it back to the manufacturer?
Hello
Have you tried contacting the provider and/or running the troubleshooting via the self-repair portal?
Thank you @Meaghan for answering this thread, I have just discovered the self-repair portal, AND the fact that my fairphone is still under warranty, and that I possibly could get it repaired! Thanks again!
