Hey all,
Just got a FP4 last month, and it’s huge compared to my last phone.
What kind of grips (like PopSockets, for example) do you recommend?
Cheers
Hey all,
Cheers
Hey,
welcome to the forum!
I use a fairphone 4 case and on that a pop socket. I am very happy with this combination.
The case to protect my fp4. Mine fell down and the color got off on an ege. At that time the case were not available to order.
The pop socket is usefull because its a huge phone and just for surfing with one hand very helpful. Also for simple calls it helps to hold the phone safely while adjusting volume.
Best regards
Sabine
Thanks Sabine, that’s exactly what I wanted to know: I also have a fp case, so was unsure grips like popsocket would work on it
Much appreciated ![]()
