My phone fell into water and now my screen is goasting and vague. Does a new screen fix this out could there also be a problem with the mainframe? Is it wise to buy a new phone or a new display?
Take a look at the waterwiki.
It’s important to let your phone dry after dismantling it.
too late unfortunately, three hours after the fall the screen started to act strange, everything else seems okay. If I had dried immediately maybe the screen would have still worked. I dried the phone for 20 hours when the screen started to fail, but after the reassembly the result was the same…
My suggestion would be still to open the phone and clean all the parts as suggested by wiki, checking also the water indicators.
Cause I am afraid the issues might be deeper than just a display.
If you have a local Angel nearby you could try swapping the display after cleaning and drying the phone.
