Phone doesnt charge
Hi guys,
so my phone doesn’t charge right. Sometimes it does and sometimes not. I have to turn it of and then there is the android notification where I have to choose that the USB will charge that device and not the way around. Also when I turn it off for charging, it sounds like turning on and off again, like in a loop. It vibrates all the time - as if it would turn it on itself. Pretty weird.
So I tried a couple of different chargers and cables. I tried to change the adjustments but nothing works.
do you have any ideas?
Thank you
Check basics like memory available and SD card formatting.
  • Try using safe mode
  • Clean the port
  • Dismantle and clean the inner contacts
  • If you can save your data try a factory reset
Read this topic for some more detail and links to other users experiences
