Phone disconnecting from WiFi network
Hi! Having used FP6 since about April this year, the last couple of months I’ve experienced trouble with my phone randomly disconnecting from WiFi networks, independently of if I also have enabled mobile network (5G) or not. Never experienced that it’s disconnected itself from the mobile network, though. I didn’t have this problem until this fall, so I suppose it’s something in one of the resent updates which bugs the connection. Sometimes it just disconnected, and I find the network disconnected, tap it and connect again, sometimes my phone claims there’s some connection problems and won’t connect until I’ve switched off/on WiFi or on/off flight mode and I try again.
Anyone else having experienced similar issue? Could you solve it somehow?
Hi, same thing has been happening to me for a few months now. It’s very inconsistent and there’s no way for me to replicate the issue. Most of the time it happens to me, the network is still shown in the wi-fi window with 4-5 bars, I can click on it but it doesn’t connect. Most of the time turning airplane mode on and off fixes it, same goes for a phone restart.
I have checked both wifi & wired connections on other devices when this happens and it’s always only my phone that’s disconnected from the router while every other device is still online, so I think I can safely rule out a router issue.
