After updating to 4.1.1 on Fairphone 6 my Phonak hearing aids no longer connect via Bluetooth.
Had been ok under all previous versions of EOS.
Can I revert to earlier EOS to fix this until this issue is fixed in later EOS?
Thanks
James
Thanks
James
It depends if your bootloader is locked or not.
If it’s not locked, then you might manually install an older eos version. Still a downgrade always carries a certain risk regarding the data on the device.
Thanks for your info. I suspect I’ll need to wait until eOS has fixed this in a later version.
James
