As in the subject. I can’t make it to work. It works on any other phone/pc no matter the OS: Linux/Windows and Mac, but it does not work on FP5.
I go to networks, I select network:
EAP method: PEAP
Phase 2: MSCHAPV2
CA Cert: Do not validate/Added cert
Identity: {{username}}
Anonymous identity: {{empty}}
Password: {{user password}}
In advanced options I only select {{Use device MAC}} since I use MAC filtering on my firewall.
I click connect aaaaand {farting noises} it does not work. I spent last 2 days using different configurations,
I tried CA certs,
I tried User p12 certs, but for some reason not a single one can be unpacked with default or custom passwords…
I tried updating OS using Hotspot network.
I tried using different credentials that are working on other devices
I tried using credentials on other devices - they work.
I tried using different domain names
I tried creating new CA with more custom options and domains.
The phone was only unpacked. Nothing freaking works to solve this issue and it’s just a WiFi connection. I don’t want to create a new network for the Fairphone since I am using Radius to avoid 10 different networks for different vlans. So what else can I try?
It’s credential based. Radius allows any user that has correct credentials… The firewall has MAC filtering on the whole network or rather virtual network(vlan).
The credentials that I am using on this Fairphone are working perfectly fine on other devices, other OSes and even other Android phones do not have this issue.
That is why I am asking for help from the infastructure standpoint everything is working fine for 10+ devices with different OSes on those devices.
Okay I was able to fix it:
EAP: PEAP
Phase2: MSCHAPV2
CA certificate: {{CA certificate from firewall}}
Online Certificate status: Do not verify
Domain: {Common Name of the certificate - something like www.yourdomain.com or company name - I changed it when generating new cert for Radius}}
Advanced in advanced I only changed “Use device MAC”
It seems that selecting
CA Cert: Do not validate, Does not allow network to be saved/used, even if correct credentials and other settings are provided.
In my case I needed to generate a completely new CA cert in firewall with new “Common Name” for eg. “www.example.com”
Then add it to Radius config;
Download CA.crt file;
Add it to Wi-Fi cert store on Fairphone for eg. “RadiusCERT”;
Select it from from dropdown “CA certificate” when defining new connection it will appear as saved in Wifi Cert store eg. “RadiusCERT”;
Put my custom domain(Common Name of the certificate) in Domain field: “www.example.com”;
Re-enter credentials;
Change in advanced settings to “Use device MAC” for this connection;
Click connect;
And this time it worked;
