On my Fairphon 3 I installed /e/OS and the OpenLauncher. Everythink works perfectly except when I install an app or run an update of an app some apps on the “desktop” are getting reordered. Especially widgets are suddenly on top of or behind other apps. Can anyone reproduce this or knows how to fix this? I install or update apps via Aptoid, F-droid or the default app store of /e/.
/e/ is officially beta software and OpenLauncher is not the default launcher for /e/. I would recommend searching the /e/ Community forum
or checking the issues list for OpenLauncher over at GitHub
Issues · OpenLauncherTeam/openlauncher · GitHub
Good luck,
Thomas
