I use LOS 14.1 (20 june 2018) and I wanna install the build from 4th august.
How is it working ? I just flash it with the SU and then everything is done ?
Am I going to lose any settings on my phone or apps ?
It would be better to wait until the official build of 15.1 hits this week (tomorrow maybe?). The 4th Aug is an unofficial build and you’d then need to take additional steps to migrate to the official build.
When you do upgrade on the official build, you won’t loose any settings/apps.
This post contains details of how to upgrade ONCE the official version is available to download (don’t forget if you’re using gapps that you need to flash gapps for 8.1 before you reboot after flashing the new 15.1 build).
Probably not directly, since the bulds are provided on a LineageOS server. You’ll find the download here https://download.lineageos.org/FP2
Just check for the latest 'nightly" 15.1 build.
Just installed the new 15.1 incl. microg. Upgrade went smooth. I did a System wipe to be sure, eventhough on the microg page it was said that no wipe at all is necessary.
Everything seems to work fine at the moment. However I don’t get the weather Information working in th Clock app.
Booting time did not change a lot I have the feeling. Apart from some nice design changes I did not see many other changes yet!
Thank you very much for your effort!! One step more to use the phone longer!
Same here.
Just installed Lineage for microG without wiping anything and it worked!
Everything works as it should.
Thank you very much for making Lineage OS 15.1 happen for FP2!!
