Oooh. Ohhh. Lineage 15.1 (testing)
Thank you very much! (Albeit I don’t use GSuite… Which makes migration even easier.)
Is there anything a thankful beneficiary could do to keep you happily doing what you’re doing?
Awesome ! Thank you a lot Chris :smiley:
We just need to wait for tomorrow for an official 15.1 build, right now there are only 14.1 ones :wink:
Apparently, @chrmhoffmann doesn’t have the 12 megapixel camera yet ! An idea could be to collectively buy one for him as a gift, what do you think ??
Woaw! That was a super fast development! Congratulations and many thanks!!
Two questions:
  • I guess that means that there will be also a lineage+microg-Version then?
  • How does the upgrade work if my phone is currently encrypted (TWRP 3.2.2.-0)? Could you tell me the steps I need to take?
Many thanks again! The camera module sounds like an idea!
It has not been approved yet, so we most likely miss this week’s build.
Chris
I have the same question.
I think Fairphone would be great if they would offer @chrmhoffmann an entire phone with the new camera so that he can run his tests there! If not, I’m in for co-funding a camera set for him.
I don’t think I need the new camera. All lineage bugs related to new camera are apparently also on fpos. :wink:
Chris
You don’t need twrp to decrypt data just to install a new version.
Chris
For updates of 14.1 to a newer 14.1 or of 15.1 to a newer 15.1, yes.
But what about the upgrade from 14.1 to 15.1?
Oh no… So exited to install 15.1! Fingers crossed that it’s still gonna happen this week :slight_smile:
Same. The only difference is that you MUST flash new gapps RIGHT after the initial 15.1 package without rebooting.
Chris
I hope that the twrp encryption part for 15.1 will be fixed soon, as I would like to use it as a backup for such upgrades (14.1 to 15.1).
Just to make it 100% clear: that can be done by selecting both ZIPs in the right order in the same install process, right?
Yes.
After you selected a ZIP for installation in TWRP, you can choose “Add more Zips” to select another ZIP to install right after the one before in one go, and so on … there’s a limit of 10 Zips I think.
If 15.1 can just use a 14.1-encrypted data partition as @chrmhoffmann suggests here, TWRP would work already. We’ll see :slight_smile: .
Ok, scrap that.
so what else :beer:?
already do what now :blush:
Donate more, obviously :slight_smile: ?
Edit: Oh, there was something else, too …
