I found these pretty straight forward when I installed LineageOS on my FP5.
Granted I was still lucky that my FP had a FPOS based on Android 13 when I followed this. It seems a little bit more hassle if you already have FPOS based on Android 14.
Since most of the steps that are required are all written out pretty clear by others (Fairphone and LineageOS), Iâll just point you to the documentation I would use to achieve the installation of LineageOS on a FP5 that has already A14 installed.
Be certain to have a backup of all your important data because this step will wipe all your data from your device.
Make sure to download the A13 version offered on the page.
Go through the steps âflashing with fastbootâ. This will allow you to downgrade from A14 to A13.
Remarks:
Be sure to have a backup from all your data as âflashing with fastbootâ will wipe all your data.
To me the step on how to install fastboot seems to be missing here either you follow the guide on Lineage on how to install adb and fastboot or if you are on any Linux distro you can use your package manager to install fastboot, which is often bundled with adb in the package âplatform-toolsâ.
If you are somewhat familiar with scripts, there seems to be a dry run and data wipe switch in the script Fairphone provides. By setting data wipe to false and dry run to true, you should be able to make a test run without making changes to your device
To me it is not entirely clear if the script to install FPOS with fastboot also locks the bootloader again, so it is possible you have to unlock the bootloader again when installing LineageOS.
EDIT: I just see @hairyfred already posted this information for the downgrade a few post above this one. Maybe he can provide more feedback since he has executed those steps.
My understanding was, that the FP5 has a rollback protection. Doesnât this cause trouble when downgrading to an older android version? As Fairphone describes it on their official page it should work, but I donât understand what the rollback protection then does?
So if I use the official documentation from Fairphone to downgrade e.g. from A14 to A13, I need to make sure that I do lock the bootloader, even if that is not mentioned on the support site although it mentions the option to downgrade?
Sorry, I should have been more clear. I was referring to the post directly above mine:
And a bit below in the same post
That confused me, because I was also under the impression that locking the bootloader is not possible after downgrade.
If you check out Install FairphoneOS manually, it states that you can use the fastboot method to downgrade:
âWorks regardless of what version you are on. Can be used to downgrade to an older version (for example: Android 13 â Android 11).â
I would have expected a warning about locking the bootloader here. In the linked documentation about unlocking the bootloader, there is a warning:
âIf you install an OS with an older security patch level than your previous OS, Androidâs roll-back protection might brick your device when locking the bootloader!â
Why do they write âmight brick your deviceâ?
So my takeaway from this is: After using the script to downgrade to A13, check the bootloader state before rebooting.
Do I need to reboot at all, or can I start installing LOS when Iâm in fastboot mode anyway?
So to my knowledge the FP script does not lock the bootloader automatically as e.g. the Calyx script does, so downgrading, booting into system and after that isntalling LOS should work out. With LOS you cant lock the bootloader its not support, thus it will stay open. If you want a locked bootloader and avoid the downgrade step, check-out IodeOS or CalyxOS.
This can always happen irrespective of downgrade part
The most important warning is
If you install an OS with an older security patch level than your previous OS, Androidâs roll-back protection might brick your device when locking the bootloader! Wait until you get a software update with the same or newer security patch level before locking the bootloader.
I apologize for the confusion about the fact if the bootloader should be locked or not.
Like multiple people have stated before me: Do not lock it yourself unless you know what you are doing.
My initial note was to indicate I was not sure if the script locked the bootloader again (It seems established now it doesnât lock the bootloader again) and I could be possible you had to unlock it again before installing LineageOS.
Just to clarify this:
no script can lock the bootloader. It can only trigger the process to lock it. But your phone will always ask you to confirm before the bootloader is locked. So if you think (and deny) before tapping an answer you are always on the safe side.
Does anyone know how to contact the developer(s) working on LOS for FP5? Iâm experiencing issues with D2TW. There is a âbug bucketâ on gitlab for LOS but no one seems to look into it. Thank you.
Oh thatâs too bad. DT2S is not working for me either. What do you mean with âSwitch on and unlock with a tap at the power switchâ? Where can I find this option?
