Well, if you want the newer Android (14) on your fp3 you can switch to LineageOS 21 as I am running it.
Additional advantage: the fingerprint sensor is working fine!
Since upgrading to LOS 21, I can’t set different notification sounds (email, calendar, SMS…)
I always hear the standard sound, does it work on your phones?
I did a quick test with a user-app (non-stock-app), works fine for me.
Ok, my email and SMS Programs are also 3rd Party ones, but thanks for checking
Have you made a bug report, was it solved?
I thought this was already reported because LOS20 had the same issues (was a bit less laggy but still laggy) according to the LOS20 thread, if I remember correctly. I will check soon & report if it’s not reported already.
Thanks so much for keeping the FP3 alive!
Would you guys recommend LineageOS 20 or 21 for the Fairphone 3 when it comes to stability and speed? Thank you so much!
Hi All,
I unfortunately could not get much time recently and hence I am unable to reach the deadline set by LineageOS to get QPR3 work on FP3.
As a result, there will not be updates to FP3/3+ for the next 2-3 weeks. Apologies for this. I shall try to get back as soon as possible. Sorry for the inconvenience.
Thanks.
In a nutshell:
In this respect, I don’t notice any difference between LOS 20 or 21, so I advise you to choose LOS 21
btw it seems i can’t edit photos anymore with the new gallery app
it tells me no suitable apps is installed… it seems the new app can only display/sort pictures…
So, want someone recommend a good small photo edit app? from f-droid if possible :3
Fossify Gallery should do it.
Micro-G for LineageOS : popular as an open-source alternative to the Google Mobile Services (a.k.a. Google Apps).
Does anyone know which version of Micro-G this build uses? (The retirement of the Mozilla location service is causing some headaches at the moment, and the precise impact depends on the Micro-G version.)
Last Wednesday there was no update. What had happened? Just a change of the build day or dropped support?
see here ^^
An update on this,
All set now. Builds should be back from next week. Sorry for the delay.
There shall be no more delays for LineageOS 21 since there are no major updates coming for Android 14 in future as QPR3 was the last major update.
Thanks.
Thank you for all this work. It is very appreciated!
I concur wholeheartedly with @Grimmwolf
Thank you very much for all your hard work!
I just uograded to the new release (thanks for that, btw!), but now my phone will no longer connect to my home wifi. Am I the only one with this issue, or is this more widespread?
Same here. With a fritzbox 7490.
I see the same symptom, although not quite as bad. The pulldown menu noticeably stutters when pulling it down while media controls are visible, but I don’t notice any input lag.
Interestingly, the animated map on my weather app (DWD Warnwetter), which used to lead to heavy framerate loss when playing, or when being visible in the app overview, now runs silky smooth.
