Installation went perfectly, official lineageos is installed, 2nd camera locks up when used.
Does the wideangle camera working in Lineage OS? Does the 48 MP-Resolution working?
Is Volte and VoWIFI ok?
Not tried it yet but AFAIK until Fairphone themselves fixes it external apps cannot use the wideangle camera? They do some non-standard stuff with the access to the camera.
I wish they were more open about both the intent to fix the software issues and the progress on them. For a phone this open to repair, the bad software side (camera, ARcore, that kind of stuff) is really annoying. I hope LineageOS can find custom fixes though, at least with root we can fix the missing ARcore.
Does the wide-angle camera working in Lineage OS? Does the 48 MP-Resolution working?
Well, the wide angle lens should work as it also works with FPOS and Gcam. A solution how to access the 48MP would be great though, for LineageOS and FPOS.
Wide angle works fine canāt test Volte and VoWIFI.
How is connecting to a Windows PC working for you guys? After reinstalling mine doesnāt show up in the explorer anymore. ADB still recognizes it and Iāve set it to file transfer
I run Linux, but had no issues. Make sure you have the correct USB drivers installed, for me it shows up as āGoogle Inc. Nexus/Pixel Device (MTP + debug)ā
Itās telling me that Android ADB Interface is the only compatible driver and I failed to check which one I used earlier⦠Thereās always something I forget when making backups
Edit: Welp, itās no longer showing up in ADB either. Guess something else is wrong
Edit 2: Now Iāve got it showing up in explorer but still not in ADB. I donāt even know whatās happening
Edit 3: Nevermind, my phone thought disabling USB debugging would be a funny prank. Iāve reinstalled the driver as āSAMSUNG Android ADB Interfaceā and now both works
Thanks for the microG-build @tfbb!
Would you mind building another up-to-date image? I would build it myself, but it seems like 24 GB of RAM arenāt sufficient for that any more⦠![]()
Quick question, is rooting via magisk.zip still a thing? Cause installing via fastboot flash boot patched.img gives me this:
target reported max download size of 1073741824 bytes
sending ābootā (98304 KB)ā¦
OKAY [ 3.082s]
writing ābootāā¦
FAILED (remote: size too large)
finished. total time: 3.088s
Which doesnāt really help me since the max download size is way larger than the file
You might want to take a look over here: Installation | Magisk
Yeah, that is exactly what Iām doing, it just doesnāt work. I tried patching the boot.img again but after having been in fastboot and restarting the phone Windows again doesnāt list the it in the explorer. When I set āUse USBā to PTP it does show my phone and I can see the pictures on it but when I set it to File Transfer nothing happens (ADB still detects it)
Are there official Fairphone USB drivers? Or which ones should I use?
I use Linux, so I have no idea about driver stuff, sorry.
I fixed the ānot being able to install a patched imgā by sideloading the zip so my only problem is not being able to transfer files via USB. That is going to be very annoying but at least I can live with that as long as my phone is rooted
No it does not work with Gcam. However it works on e/OS, Iode and CalysOS
@t_aus_m : regarding a new build: Iāll do so in mid-January - thatās when the monthly lineageos-updates will be merged into the repos. And yes, building lineageos on desktop hardware is getting next to impossible ![]()
fwiw, the FP4 is now officially supported by lineageos: Changelog 27 - Thriving Thirteen, Amazing Aperture, Careful Commonization ā LineageOS ā LineageOS Android Distribution . builds on https://download.lineage.microg.org/ should become available soon, i guess ![]()
Hello, first post here but I lurked for some time ![]()
I started building microG images a while ago, you can find them here: https://paprika.valo.space/lineageos/
Hereās the latest: https://paprika.valo.space/lineageos/builds/full/lineage-20.0-20230102-UNOFFICIAL-FP4.zip
Images have the OTA update url set to my server so whenever Iāll build an image it will show up in the updater.
Iām using test keys, Iāll stop building images once lineage4microg will start building for FP4 and lineage 20 in general.
Just FYI Iām building the images on my laptop with 16GB RAM, Iām adding 16GB swapfile and the build successfully completes ![]()
For completeness hereās my build command:
sudo docker run --rm \
-e "BRANCH_NAME=lineage-20.0" \
-e "DEVICE_LIST=FP4" \
-e "SIGNATURE_SPOOFING=restricted" \
-e "WITH_GMS=true" \
-e "PARALLEL_JOBS=12" \
-e "OTA_URL=https://paprika.valo.space/lineageos/api" \
-e "ZIP_SUBDIR=false" \
-v "$PWD/lineage:/srv/src" \
-v "$PWD/zips:/srv/zips" \
-v "$PWD/logs:/srv/logs" \
-v "$PWD/cache:/srv/ccache" \
-v "$PWD/manifests:/srv/local_manifests" \
lineageos4microg/docker-lineage-cicd:lineage-20
fp4.xml manifest:
<?xml version="1.0" encoding="UTF-8"?>
<manifest>
<remote name="device" fetch="https://github.com" revision="lineage-20" />
<remote name="kernel" fetch="https://github.com" revision="lineage-20" />
<project path="device/fairphone/FP4" name="LineageOS/android_device_fairphone_FP4" remote="device" />
<project path="kernel/fairphone/sm7225" remote="kernel" name="LineageOS/android_kernel_fairphone_sm7225" />
</manifest>
microg.xml manifest
<manifest>
<project path="vendor/partner_gms" name="lineageos4microg/android_vendor_partner_gms" remote="github" revision="master" />
</manifest>
Thanks for your response. Just fyi, mid-Janurary will also be the time when the Lineage4microG-build will probably be available, as per Lineage 20 by bananer Ā· Pull Request #366 Ā· lineageos4microg/docker-lineage-cicd Ā· GitHub
Welcome to the forum and thank you very much for the builds!
Iāll probably test yours some time this week and also switch once the āofficialā Lineage4microG is available.
Your build-setup sounds interesting. Iāve tried building on two machines so far: My desktop PC with 16 GB of ram and 16 GB of swap, on there the build fails even with only two concurrent jobs. My notebook has 24 GB of ram but no swap and of course also failed. Iām using the docker image for building. How about you?
Thanks ![]()
Iām using the build as daily driver and no issues so far.
Iām building on my laptop which is an AMD Ryzen 7 4800H with 16GB RAM + 16GB swapfile, concurrency is set to 12.
I leave the build running overnight without any other SW running. Having cache enabled Iām not sure about build time, last took only 40minutes.
One thing I overlooked a couple of times and led to failures was that I wasnāt using lineage-20 image tag.
Hope it helps
