No hard turn off/no screen shots
Yesterday evening I found out I cannot use the off switch on my FP6
The combination of switches does not work.
Neither does the option for making a screenshot work.
How can I fix this?
Welcome to the Community Forum.
Is the power button completely unresponsive or does it trigger the Digital Assistant? If it is the latter, this can be changed in the Settings > System > Gestures menu. You can also check the screenshot shortcut there.
Thanks for the welcome and the help!
This solved my issue with getting to the menu to switch of my phone (and incidentally also to get rid of seeing the digital assistant to often :slight_smile: )
And it also solved my screen shot problem, when I turned my phone off and back on again, that also started working again!
