just looked: my FP2 3,5 years young, operation time (Betriebszeit): 90h51m β still much too short, or?
But problem: since some weeks β maybe after the last update to FP OS 19.08.1, Android 7.1.2? β the WLAN signals often are not automatically updated. Sometimes I have to go just into the WLAN overwiew and after some seconds the WLAN list will updated and it connects to the default/usual/known WLAN.
But sometimes β just now β I have to switch off and on the WLAN signal to update the list and to let the FP2 connect to the default one.
Therefore itβs really annoying and I do not know the cause. I did not change any setting (at least not with intention).
Any idea or better: the solution?
Thanks a lot and Happy WLAN!
webaschtl
