In the Netherlands all UPC Wifispots are converted to Ziggo Wifispots. Now I try to connect to the new shared WiFi network Ziggo, but I don’t get it working on the FP1.
The have a manual for Android, I tried both methods several times, but don’t get a connection.
I don’t have problems with a Sony Android, and Windows computers.
does your password uses some “unusual” characters?
Sometimes if a software is not implemented very well it might have problems with the encoding of these characters. Have you tryed to set your password to a simple one (just base characters and numbers), just for test issues?
Yes, several times. Then a restart of FP1 and then retry to make/configure the WiFi connection again. Did not solve it. Still the authentication error.
Other WiFi ssid connections are no problem, only this Ziggo ssid.
As Ziggo was UPC, it’s said that you can not log in to your own UPC-Wifipsot. Now with Ziggo I suppose it is the same here therefore you can not log in to your own Ziggo access point (your modem @home). You have to use a Ziggo access point from someone in the neighbourhood.
