Did anyone notice that the NFC icon in quick settings is always gray and doesn’t change color when activated/deactivated? It looks out of place because of that.
I know it’s just a small cosmetic issue. I just wanted to ask owners of other FF models if you have the same problem with the icon, I guess this is an old issue, and there is no chance of it being fixed given its low priority.
Are the screenshots showing the issue? If so I dont get.
All other icons invert their colors when activated/deactivated, but the NFC icon stays grey in every state.
Not in the screenshots provided.
What do you mean? The NFC icon clearly has a different color compared to other icons, in both disabled and enabled states, which I showed in screenshots
The tile changes colour, while ok the icon not..for me the tile is important
Yes, the tile itself is working properly. As I said, it is just a minor cosmetic defect. And it looks like other people have difficulty even noticing it. I wonder how many versions ago this bug was first introduced
FYI: On /e/OS the NFC-icon-shade is accurate with every icon theme. It also seems like the NFC-icon is the only one that is customized by Fairphone in FPOS, since it is the only one that looks different from Androids stock icons.
I did notice ![]()
The FP4 also has a grey NFC icon even when activated. All other activated modules have a black icon.
