My three navigation buttons at the bottom of the screen are not working. Any ideas what I can do??
Do the Touchscreen Test and if it shows faulty behavior contact support with the results.
Meanwhile you can use Gravity Box (Xposed Module) to get on-screen navigation buttons.
Thanks for this. The onscreen test showed the red boxes at the bottom of the screen aren’t working. I guess I must send my phone off then, for repair?
Not sure how I find out where to send it off to!?
Send a question to support. They will guide you through the replacement process.
Thank you! I have sent an email and will wait for a response. I am not savvy about all this but liek my Fairphone and need it working properly! Thanks again, Refugee Welcomer
If you also want to welcome refugees, take a look here
This topic was automatically closed 34 hours after the last reply. New replies are no longer allowed.
